2nd FitBit Sense that will not charge
This is the second device I've had that just packs up. Now there is no live chat support even though it says there is. Veeery annoying.
1 REPLY 1
Hi, @justjennie55 , welcome to the community, I suggest you use the search bar where you will see a number of conversations about charging. Briefly check the 4 little pins on the charging cable are slightly proud of the mating surface and free (they are spring loaded) If they are not in order contact "Customer Support" for a replacement cable, alternatively you can buy them at a modest cost on Amazon. You might also review Why isn't my Fitbit device's battery charging?  if you still have a problem. Finally, clean the back of your "Sense", I use rubbing alcohol with a cotton wool swab and a cotton bud to detail the pits that locate the pins on the cable.
I hope this helps.
Cheers
Gr4ndp4 | UK
