08-15-2022 17:32
08-15-2022 17:32
Tried all troubleshooting and it's a complete mess. Was working perfectly prior to upgrade so seems very likely it has to do with Android 13 upgrade. Does anybody have any ideas or workarounds? This is quite frustrating given Fitbit is owned by Google.
08-15-2022 18:03
08-15-2022 18:03
Same issue since first Android 13 Beta. Connection has been mostly non-existent with very infrequent periods where it sometimes syncs.
08-16-2022 03:03
08-16-2022 03:03
Same here with the versa 3
08-16-2022 03:15
08-16-2022 04:20
08-16-2022 04:20
Hi all, there is a bug in the latest version of the Fitbit App that stops notifications coming through to the watch.
08-16-2022 04:24
08-16-2022 04:24
Same issue for me Since updating to Android 13 yesterday. Before that (Android 12) syncing was solid, now it's completely broken. Also this means Google assistant isn't working and notifications.
08-16-2022 05:34
08-16-2022 05:34
Updated my Pixel 5 this morning to Android 13 and since then my Sense won't sync either.
08-16-2022 05:36
08-16-2022 05:36
Not disputing your comment, but it must be more than just the latest app. As soon as I updated up Android 13 beta (on a Pixel 4a) things have been this was. Last week, to get a firmware update, I had to connect my phone to an old Nexus 6P. That worked fine. Now I can barely get either phone to recognize the watch.
08-16-2022 06:11 - edited 08-16-2022 06:12
I don't think it's the app. The moment I installed 13 beta, Fitbit app stopped communication with Sense. Many beta testers opened tickets with Google. For me, Bluetooth won't pair and app can't find wifi.
08-16-2022 06:30
08-16-2022 06:30
Fitbit Sense + Pixel 5 = broken since android 13 update.
I use my Sense with type 1 diabetes monitoring. This really screwed that up, and my confidence and trust with Google + Fitbit (really, same company) is now seriously shaken.
Ill switch my entire family immediately to apple if necessary, because type 1 diabetes isn't a joke.
Hopefully they fix this shortly. I know my opinion doesn't matter as I am a drop in the bucket regardless of any platitudes.
08-16-2022 06:48
08-16-2022 06:48
Same problem.
Pixel 5 (Android 13) + Sense
worked perfectly before upgrade
08-16-2022 07:41
08-16-2022 07:41
Same thing here. After upgrade to android 13 on my Pixel 6 pro. My Fitbit Sense will not sync to my phone. This is very frustrating that google is trying to make a eco system of devices like Apple, but are failing miserably. You would at least think Fitbit and Google would give a notice to of problem.
08-16-2022 07:42
08-16-2022 07:42
I have the same problem. Everything worked until the android 13 update with my sense and pixel 5. Now, my watch won't sync and notifications will not come through. I've tried every fix and none have helped.
08-16-2022 08:05
08-16-2022 08:05
Thanks Google. Listen to us please. You've created these things for us to rely on, so please keep them fixed/updated in a timely manner. Should be a simple enough ask since you've beta'd it and Fitbit is YOUR product!
08-16-2022 08:08
08-16-2022 08:08
My Charge 5 was syncing fine on Android 13 Beta (Pixel 6), but since updating to the mainline release yesterday it seems to be broken. Realtime stats are still working, but heart health and sleep reports haven't updated. The app shows a higher battery level than is displayed on the device, and it says last sync was at 9:39 pm last night. FWIW I updated Android a few hours before that in the afternoon.
Best Answer08-16-2022 08:51
08-16-2022 08:51
I was able to update to the latest version of the Fitbit app by just turning my VPN on. (In the UK and Vpn also in UK) The latest app update was then available. Seems to be working ok. Poor stuff again by Google / Fitbit.
Best Answer08-16-2022 08:59
08-16-2022 08:59
Updated the app and still no luck
Best Answer08-16-2022 09:01
08-16-2022 09:01
It has been happening since Android 13 beta 3, I have notified to Fitbit and Google, but now with the final official Android 13 is the same thing. Couldn't complain much as it was beta, but now with the official it is just unacceptable Google / Fitbit, they knew about it and released it nonetheless.
08-16-2022 09:02
08-16-2022 09:02
Best Answer08-16-2022 09:06
08-16-2022 09:06
Same problem with my Sense and Pixel 4XL, sync was good initially after Android 13 update but dropped during yesterday evening and would not reconnect after trying all troubleshooting options until I deleted the Sense from my Pixel bluetooth and added it again as a new device. Sync worked again for an hour or so then by morning failed to sync again no matter what I tried.
Sync is working properly via the Windows App on both my Desktop and my HP laptop so that confirms the issue is with the Pixel 4XL (and likely the Android 13 update) and is not a problem with the Sense itself.
