12-28-2021 13:42
12-28-2021 13:42
I have only had my sense for 4 months and am currently getting 2 days maximum on a charge I have read all of the other suggestions to turn this off and turn that off but if I turn everything off what good is it having a smartwatch I could have bought a pedometer for much less
Best Answer12-28-2021 13:47
12-28-2021 13:47
If you have the snore feature on, I found that that significantly kills battery life. To turn it off, it's in the sleep score area.
12-28-2021 21:50
12-28-2021 21:50
HI @Lauravt77 - see How to resolve the Major issues causing short battery life. It's up to you to choose which options you need, or wish to eliminate to have long battery life if that is more important - you can't have both.
Best Answer12-29-2021 11:02
12-29-2021 11:02
12-29-2021
11:09
16:08
12-29-2021
11:09
16:08
@Lauravt77 - you can use the information to locate if you have a particular feature causing a problem.
If the issue came following an update (firmware or Fitbit App) it could always be a bug.
Again you might be able to work around it temporarily by knowing what area is problematic.
