03-08-2022 15:59
03-08-2022 15:59
Brand new Sense won't hold a charge longer then two days. My Fitbit HR lasted longer. What's the point of having one if you constantly have to charge it?
03-08-2022 23:09
03-08-2022 23:09
Hi @OneofLostgirls - if you use all the features all the time it will drain the battery.
Features such as Snore detection [premium members] and SpO2 will drain the battery by about 4 days alone.
Check and disable those you don't need - How to resolve the Major issues causing short battery life.
Best Answer03-09-2022 01:21
03-09-2022 01:21
Sorry to hear that your Fitbit Sense's battery is draining quickly and thank you for troubleshooting this issue. Have you charged your tracker since you set it up? The setup process does impact the battery specially if you include the firmware update. Still I suggest you try charging it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter.
Best Answer03-09-2022 02:28
03-09-2022 02:28
Mine too I am very disappointed 😞
03-09-2022 02:31
03-09-2022 02:31
I had the upgraded to the sence as well and mine lasts 2 days if that. So dissatisfied. The virsa lite I had is way better.
Best Answer03-09-2022 21:39
03-09-2022 21:39
Hi @LisaCooper71 - did you read the first reply in this thread, it will resolve the problem.
