02-02-2021 10:22
02-02-2021 10:22
I have just given away my amazing charge 3. Bought the Sense as it’s supposed to be better. Well I have to charge this ever 2 days my charge lasted a week even with me walking 10 km every day. Messaging etc I find it drains overnight too. This is a huge flaw and I would like you people to fix this and replace my watch when you do. This is just awful. I paid double for this watch to. I noticed everyone has the same problem.
Best Answer02-03-2021 02:30 - edited 02-03-2021 02:35
Having the spO2 app installed vs not installed reduces my battery life (I've tested extensively) from around 5-6 days to 3-4 days (I don't use the clock face at all). So throw in a bit of GPS tracking (which I don't use often), I'd say it's absolutely plausible that the app alone could be the culprit. I'm not sure why you're not seeing the drain, but I've confirmed my own experience with multiple other users.
02-02-2021 22:42
02-02-2021 22:42
One thing you can try is if you are using the SpO2 clock face is to use another face and see if that helps.
Also remove the Always On display.
Best Answer02-02-2021 22:43
02-02-2021 22:43
If that fails get a replacement watch or try Fitbit Support They may be able to help you.
Best Answer02-03-2021 01:51 - edited 02-03-2021 01:52
Actually, I would check to see if the SpO2 "app" is installed as this will still drain battery regardless of whether the clock face is used or not. If it's not a feature you use, there are definitely battery savings to be made by removing it.
02-03-2021 02:13
02-03-2021 02:13
Thanks for the suggestion, but my Sense has it installed and my battery life is nearly 6 days, so he shouldn't have such a poor battery life, but worth investigating.
It's more like a faulty watch as it should still last at least 5 days with SpO2 tracker app.
02-03-2021 02:43
02-03-2021 02:43
Best Answer02-03-2021 03:20 - edited 02-03-2021 03:32
@Guy_ I'm sorry but it's not an issue with my clock face at all. Like I said in my previous post, without the spO2 app installed I get around 5-6 days battery life, and with it installed I get only around 3-4. The only change being the spO2 app. I can agree that some watch faces are heavy (and it's a good idea for users to also check this), which is why I stick to the same one I used as far back to the Ionic. I've confirmed the above with other users, so know it's not an issue exclusive to my device.
In fact after the last update one of my friends was scratching his head trying to work out why his battery life had almost halved (during the update the spO2 app was installed without his knowledge). I told him to check to see if he had the spO2 app installed (he did), so he removed it and normal service was resumed.
If the case is the same for @winkey26 and we also throw GPS into the equation for good measure, I could completely believe the battery could be reduced to around 2 days (we don't really know the users usage habits). Granted, if he uses GPS a lot he'd never expect the full 5-6 days even without the spO2 tracking. If it turns out that he doesn't use GPS, then yes it could indicate a hardware failure. First I think any software issues should be ruled out before deciding it's hardware related though.
02-03-2021 04:45
02-03-2021 09:19
02-03-2021 09:19
I am older and not very tech savvy where do I find the spo2 app
Best Answer02-03-2021 09:28
02-03-2021 09:28
No problem
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Click Apps Tile Under MY APPS It will list all your apps Find the SpO2 Tracker Click on it and click uninstall |
Let me know how it goes.
02-04-2021 06:50
02-04-2021 06:50
There are plenty of threads with battery life complaints about the Sense. It has 2 days at best, whereas my old Charge, Versa, and Versa 2 could all manage a week easily. I have factory reset it then uninstalled and disabled everything I can on this thing and there were no gains. There's an issue with it and it badly needs investigating.
02-04-2021 06:56
02-04-2021 07:03 - edited 02-05-2021 04:36
Replace it? I returned my first two for replacements, due to faults, and each still has a 2 day battery life. Nothing extra installed, and everything removed or disabled that I can, and no SPO2 watch face or app.
Best Answer02-05-2021 03:23
02-05-2021 03:23
Thanks for the tip about the SpO2 app! I was lucky to get three days before having to sync (and I have a basic clock face). I deleted the app and, after 35 hours, my Sense is still at 85% charge.
02-05-2021 03:28
02-05-2021 03:28
@slbert Glad to hear it helped.
Best Answer02-05-2021 20:04
02-05-2021 20:04
I did not have the Sp02 installed but I took off the always on and I am getting more life. Thank you
Best Answer02-05-2021 22:45
02-05-2021 22:45
@winkey26 Yes the AOD is a big battery drain. Personally I've never used it as I don't see the point in having the screen on when it's covered by my sleeve 95% of the time.
Best Answer02-06-2021 03:44
02-06-2021 03:44
If it helps I just posted a review of the battery if you are looking for a comparison for what is and is not normal.
https://community.fitbit.com/t5/Sense/Fitbit-Sense-battery-review/td-p/4710422
Best Answer02-10-2021 02:17 - edited 02-10-2021 02:21
After taking @N8teGee's suggestion about deleting the SpO2 app, I went from almost three days charge to 6 1/2 days (I recharged at 24%). I still have notifications on but turned calls off (since I don't use it). No GPS used and exercising between 1-2 hours per day. Hopefully in the future, Fitbit can solve the massive battery drain but, until then, I'll not bother with the SpO2.
