06-20-2021 20:16
06-20-2021 20:16
Hi, I am just wondering if this performance is normal. I just received a sense 5 days ago and have been using it relatively frequently. I have set up the watch to have the always on display and downloaded multiple apps. I don't use the apps that much, but is just having them on the sense possibly draining the battery faster? I was really expecting at least 3 to days of battery life with the advertised 6 day time frame. Is it possible my device is defective? I have an android device so I didn't think I would be affected by the IOS battery update issue.
06-20-2021 20:27
06-20-2021 20:27
That would be the "always-on display".
On the similar Versa 3, in Settings where turn on 'always-on display', it say battery lasts about 2 days.
If not familiar with Fitbits, display should come on when turn wrist to look at without using the always-on display.
06-27-2021 07:36
06-27-2021 07:36
So Even after following up with someone over the phone, turning off batter intensive settings, deleting all apps except fitbit apps, and keeping the display off I am still experiencing a 2 day battery with my fitbit VS the advertised 4 to 6 days. This is a gut punch considering how much money I spent on this. I am incredibly unhappy with the performance of this product. I am curious, what is the likelihood I have a Sense with a faulty battery vs fitbit just lied about the performance the device is capable of. Is anyone else getting a 2 day battery life with an Android device, so this seems unrelated to IOS issues
06-27-2021 07:38
06-27-2021 07:38
As stated the always on display is turned off.
06-27-2021 07:53
06-27-2021 07:53
Whoops I am sorry, I made a follow up post to this and thought you were responding to that, I actually killed the always on display and am still having the shortened battery life.
06-27-2021 12:25
06-27-2021 12:25
Turn off always 'on' and see if turning off bluetooth helps.
06-27-2021 12:41
06-27-2021 12:41
turn off bluetooth..
07-06-2021 18:55
07-06-2021 18:55
In having the same exact issue with my Sense and I've essentially turned everything off and keep Bluetooth off all day. It's super frustrating because I'm only getting maybe 2 days at best of battery life.
07-06-2021 19:29 - edited 07-06-2021 19:31
It turned out my battery was faulty. You shouldn't have to turn off bluetooth to get 4 days of battery life. I actually called customer service and walked through all the trouble shooting and they checked the charge history and apps running and were able to send me out a new one for free. I hope that helps. Oh also take note of when the battery is draining fastest. I would have normal battery life till about 40 percent then the last 40 percent drained super fast.
07-06-2021
21:26
08:32
07-06-2021
21:26
08:32
@bmorris83 if the battery draining issue was sudden, check you have the latest Fitbit App, the issue may have been fixed.
Also do a shutdown of the watch and place on the charger to restart.
In some cases removing the Sense Bluetooth entry from the phone and resyncing the watch helped.
If you do the last step, logout of the Fitbit app. After login, go to the home screen without closing the App, a sync pop up should appear, clicking on it should re pair and re link your watch.
07-12-2021 17:46
07-12-2021 17:46
Thanks Guy, I tried all of the steps above over the last few days and I'm still having the battery drain issue. This issue started 2 months ago and I had been waiting for the update to see if it fixed it, but no luck.
07-12-2021
22:03
08:05
07-12-2021
22:03
08:05
@bmorris83 Try temporarily turning off Bluetooth on your phone and see if the battery draining issue improves.
If so, post back which phone you have, which Fitbit App version [click profile photo => Help & support] and firmware version [click Device photo, at the top]
Or you can contact Fitbit Support directly. They may be able to help you.
