I have a Sense and just got an iPhone 13 mini. I'm having 2 problems.
1) The Sense is showing my calendar and a coworkers calendar when I tap the calendar icon. I can get rid of the coworker's calendar by deleting it from my phone as an option, but then it is also deleted as a calendar I can easily check in Outlook. I need to check his calendar rather frequently, so I do not want to delete, re-add, check his schedule, and delete it again just so it doesn't show up on my Fitbit. The other coworker calendars that show up on my phone, don't show up on my Fitbit. I have turned off all the options for the calendars in my phone, such as event alerts, events affect availability, and I even don't have them show on the phone. I'm guessing it has something to do with the permissions I've been given to my coworkers calendars, but this only started happening after getting my iPhone 13 and/or after the new fitbit software upgrade. Can anyone help me get it so that only MY calendar shows up on the fitbit even though I have other folks calendars on my iPhone?
2) Sometimes a calendar event will send me a dozen or more reminders. This usually seems to happen with day-long events. It should only happen the 1 time that it was supposed to. Can this be fixed? An example was a birthday reminder. I got 17 reminders the day before and the day of, for that person's birthday. Often the reminders were back to back as in within a second of each other. It was like a 2 year old going - Mom. Mom. Mom. Mom. Heh. Mom. Mom. Heh. ...
Best AnswerSo, after putting this here, I googled for my first problem and found a solution. In the fitbit app on the phone, I needed to take the following steps:
1) Tap on your icon in the upper left corner
2) select Sense
3) Enter the gallery or apps option
4) On the Sense page, scroll down and tap on Agenda
5) Tap on Settings
6) Deselect any calendars you don't want to see in the Agenda app on the Fitbit Sense
Still need help with my second issue.
