01-24-2021
23:48
09:01
WilsonFitbit
01-24-2021
23:48
09:01
WilsonFitbit
Help, my Sense has unpaired from my device and now when I try to pair it keeps rejecting it??????
Best Answer01-25-2021 09:00
01-25-2021 09:00
Hello @Cheryl.Clayton Welcome to the Community Forums! @NellyG It's great to see you around and thanks for your input!
I am glad to know that the inconvenience is now resolved @Cheryl.Clayton. I was able to see here that @NellyG provided some instructions in order to fix the difficulty. If the answer worked for you, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Have a great day!
Best Answer01-25-2021 01:50
01-25-2021 01:50
Hi @Cheryl.Clayton What phone are you using? Try restarting your Sense a couple of times, and turn off Bluetooth on your phone and restart that. Then turn bluetooth back and go to the fitbit app and try syncing again. If it still wont sync then try THIS Help Article on syncing problems.
Helen | Western Australia
Best Answer01-25-2021 02:16
01-25-2021 02:16
01-25-2021 09:00
Have a great day!
