Hi. I just got the Fitbit Sense. It’s my first. I don’t want to see the sleep score all day. I want to remove it and add calories burned. Is this possible? I’ve found nothing indicating I can do this.
also, no matter what I do the button on the side doesn’t register my finger. Is it possible to raise the sensitivity?
thanks,
chris
Best AnswerI had the same problem with the button. The way I fixed it is here:
https://community.fitbit.com/t5/Sense/What-I-learned-about-the-Sense-home-button/m-p/4875175#M24898
Does this work for you?
