Recently, every time I open my app I get:
"Bluetooth Pairing Request
'Sense' would like to pair with your iPhone."
Since this started showing up, my watch battery seems to be draining significantly faster than normal as well.
I have tried completely removing and re-adding the device with no change to the behavior. Any other thoughts/things to try?
Same issue. I leave the app open on my iPhone, but every time I go to check it, it says I need to pair the device again. I will go into blue tooth and forget my Sense device and then return to the app and it pairs again. Very annoying.
Reboot your phone and restart your watch. Turn on the Bluetooth only on your phone and open the Fitbit app. Tap your profile picture > Set Up a Device > Sense > Replace Device. Follow the onscreen instructions and if prompted, accept to pair your watch with your phone.
