07-01-2022 04:32
07-01-2022 04:32
Hello I am having a major issue with my sense counting steps in my sleep!
07-01-2022 06:51 - edited 07-01-2022 06:55
Hi, @Autumsmom, welcome to the community. You do not mention the magnitude of the count (How accurate are Fitbit devices?), if it's just a hundred or so you must be a restless sleeper. If it's thousands (we see such reports from time to time) no one seems to have got to the bottom of it. How do I add, edit, or delete Fitbit data and activities? indicates how you can neutralise the step count (you cant delete it). Look at the section on deleting steps and floors.
I recognise this is not a satisfactory solution but it is a workaround.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer08-14-2022 10:39
08-14-2022 10:39
Thank you, it is a low amount nothing major. I do a lot of tossing and turning in my sleep! So to say I'm a restless sleeper you would most definitely be correct. Thank you so much for the reply!
