08-11-2021
03:14
09:57
AndreaFitbit
08-11-2021
03:14
09:57
AndreaFitbit
Today my sense counted 17000 steps while driving. Contacted support and learned that is impossible to stop counting steps while driving. Thay suggested not to wear when driving.. what is point of having Fitbit product if you can't check time
Moderator edit: format.
08-11-2021 03:24 - edited 08-11-2021 03:25
Hi, @Zok, welcome to the community, you may find this article useful How do I add, edit, or delete Fitbit data and activities? , there's a section on "steps" and changing the activity to "driving". Because a number of community challenges depend on step counts there are limited changes available.
I hope this allows you to find a workaround. Have you tried restarting your Sense?
Cheers
Gr4ndp4 | UK
Cheers
Gr4ndp4 | UK
08-11-2021 04:59
08-11-2021 04:59
Couldn't find any option to reduce number of steps. I am driving bus 5 or 6 days and not being able to pose steps mean that this product is useless for me.
Best Answer08-11-2021 06:40
08-11-2021 06:40
Hi, @Zok, thanks for the update, I think you'll find all activity trackers detect "steps" from arm movement, you may find this third party article interesting How to make your fitness tracker count steps more accurately - The Verge . Rather than regard the "Steps" recorded as physical strides you can consider them a measure of your daily activity. Do look into the idea of allocating the "Steps" accumulated in your Fitbit app to "Driving", as you see this will decrease the steps, calories and floors for the time period you select.
Cheers
Gr4ndp4 | UK
