10-15-2021
19:48
16:24
LizzyFitbit
10-15-2021
19:48
16:24
LizzyFitbit
What is the distance between iPhone and sense to answer calls on the Fitbit sense
Moderator Edit: Clarified subject and updated label
Hi,
The range of the Bluetooth® connection is approximately 30 feet (10 meters). However, maximum communication range will vary depending on obstacles (person, metal, wall, etc.) or electromagnetic environment.
It may also vary depending on the battery level in the devices.
What Guy said. I’d suggest testing from different locations and ranges from your phone until you have a good sense (no pun intended).
