05-28-2022 12:40
05-28-2022 12:40
My sense is always starting the running app while i ride my motorcycle and adds the kms to my daily meters. Can this data be deleted?
Also the automatic running detection is switched off but it still starts the app.
Does this happen to anyone and how did you deal with it? Thanks
Best Answer05-28-2022 13:38
05-28-2022 13:38
@RichardV11 it's not the phone but watch. Simply, you're jacket accidently pushes the button (probably "press&hold" shortcut) triggering Run exercise automatically. Go to settings on your watch, scroll to "Shortcuts" and see whether Press&Hold is set to trigger Exercise (or anything else equally suspicious).
Best Answer05-28-2022 12:55 - edited 05-28-2022 13:00
Probably, accidentally you start the exercise by pressing the button and triggering the shortcut to the Exercise app and running.
Best Answer05-28-2022 13:01
05-28-2022 13:01
Thank you for the help. Can the phone actually start the running app without touching it with fingers. The watch is always under the motorcycle jacket while riding...sometimes it detects it as cycling which is fine, but when it starts the running app it confuses the everything. Can these undone exercises be deleted from the meters covered? Thank you
05-28-2022 13:38
Best Answer05-28-2022 13:44
05-28-2022 13:44
Yes the watch. Sorry. I will try your suggestion. Tomorrow i will know if it worked. Very much appreciated for your time!
06-01-2022 01:42
06-01-2022 01:42
Hi
Thank you for the tip. It worked perfectly. Very much appreciated.
