11-26-2020
04:22
12:34
LizzyFitbit
11-26-2020
04:22
12:34
LizzyFitbit
The microphone on my Fitbit Sense has stopped working, it worked a week or so after purchase but it wont register anything anymore. I have tried resetting both my watch and phone but nothing seems to work anymore. Is this a hardware issue or do i have a faulty product?
Best AnswerHi @Eribo have you looked under the settings (on watch) is the mic still turned on?
The phone should have nothing to do with it. Unless there is a communication error and you would have mentioned this.
Yep, its still turned on in the settings. I have tried turning it on and off a few times but that didnt resolve the issue.
Its as if the mic just cant register any sound, while it worked perfectly before
Best AnswerSame exact thing happened to me. It happened right as I got the new update, so now I can’t even use the new features. I’ve tried every conceivable remedy to no avail. I even tried contacting support, and the person said they’d create a ticket, elevate it to their superiors and email me with the conclusion.... still waiting on that email.... very aggravating as I’ve only had the sense for around a month and nothing physical has happened to it, I.e. dropping, water, etc.
hoping to get an answer on a fix soon
11-27-2020
13:06
04:29
11-27-2020
13:06
04:29
Hi @Eribo and @pinano_man. Welcome to the Community Forums. @Rich_Laue, thanks for stopping by to help our members.
@Eribo, thanks for the information provided and for the time taken to troubleshoot your watch. I'm sorry that the microphone isn't working, even though this function is turned on in the settings. Because this shouldn't be happening, I've requested a case to our Support team so they can further investigate and help you with this matter. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
@pinano_man, thanks for joining this thread and for your efforts in contacting our team. I understand how yo're feeling about this situation which isn't allowing you to use the new features. Because you already have a case created, I forwarded your post to our team so they can look into this and get in touch with you. Please keep an eye on your inbox.
See you around.
I am having the same issue. I didn't even notice it quit working. My wife called me and I answered on my watch. She kept saying she couldn't hear me. Pretty wild because it was working a few days ago when I answered a call from my brother. I then tried using assistant and voice reply to text messages and nothing works.
Also, new development although I’m not sure if it’s related (but I would assume it is since all of my issues have arisen from the new firmware), my battery fully drains in about 1/3 of a day now when it used to last 3 or 4. It will be on my wrist, screen off, doing nothing, and it will die in 8 hours easily
Best AnswerYeah, several times
Best AnswerThis is because of the SpO2 not depended on the watch face. If you did not use the SpO2 watch face before. I suggest removing the SpO2 app from your tracker.
17:51
17:04
12-04-2020
17:51
17:04
Hi everyone. It's great to see you around and welcome to our new members. @Rich_Laue, thanks for your continued assistance.
@DNC247 and @pinano_man, thanks for letting me know about your Sense and the issues that you've had with it. In regards to the microphone not working correctly, I've contacted our Support team and I was told that you'll receive a response as soon as they finish their investigation. Please keep an open communication with them so you can receive further assistance.
@MarcusMayo, thanks for joining this thread and reporting that your watch is having the same behavior. Just to confirm, is the microphone turned on under the Settings app? If that's correct, I'd recommend to restart your Sense a restart to refresh its performance. Look forward to your comments.
By the way, if you're having other issues with your Sense, I'd recommend to open a new thread and provide as many details as you can so you can receive help from the Community, and to keep the forums organized.
See you around.
Best AnswerIs there a resolution to this problem. I have tried all the troubleshooting suggestions with no luck.
The n=microphone just stopped working a week or so after I got it. Google Assistant worked great, but now with no microphone it's rendered useless.
Please advise on a recommended solution.
Thanks!
Unfortunately I’ve had that app uninstalled. I never installed it to begin with
Best Answer@Un-Fit without knowing what troubleshooting has been tried.
Agreed. I’ve done all the things I could do on my own which is why I’m here, but I haven’t received any answers or potential solutions anywhere.
It’s doubly aggravating that it appears the firmware update caused my issues, but Fitbit has been very slow to help or offer any solutions
