01-01-2021
17:28
14:25
LizzyFitbit
01-01-2021
17:28
14:25
LizzyFitbit
Has anyone else that has sleeves tattooed had trouble getting the Fitbit to connect ?
01-01-2021 17:29
01-01-2021 17:29
Just for the sense Fitbit
01-01-2021 23:08
01-01-2021 23:08
Probably some other issue.
01-01-2021 23:34
01-01-2021 23:34
@Sonya2021 Ink should not impact the connection. It may impact HR reading tho (optical sensor).
01-02-2021 12:15
01-02-2021 12:15
When on the dark ink it won’t read anything but on a small patch that has faded yellow it reads everything even my sleep so I tested solid black again and nope it didn’t work then back to faded spot it’s great. It’s being worn on the same spot just different arms . And just did a google and it seems to be a problem with the dark ink 😞
01-02-2021 12:18
01-02-2021 12:18
Hi guy I have had trouble since getting this on Xmas day ,I have managed to get it to work on the only faded bit of my arm if I swap it to the other arm the ink is not faded and it’s black and not much skin showing so believe it to be tattoo ,googled it and it does seem to be a problem with dark tattoos
01-02-2021 15:23
01-02-2021 15:23
Yes absolutely. It was driving me mad not tracking sleep, HR or O2. It wouldn't play messages and doesn't connect to Spotify... Its basically useless. I have 2 full sleeves so wearing it on the other wrist isn't an option but it works for my non tattooed partner.
My charge 2 never had this issue.
01-02-2021 15:30
01-02-2021 15:30
I have both arms it wasn’t till I found one spot that’s faded now it’s all go ,I think the older style had no problem with tattoos as they worked fine . I think Fitbit needs to come up with a way that will work on both tattoos and non tattoos
01-03-2021 14:21
01-03-2021 14:21
@Sonya2021 it's matter of sensor I would hazard a guess.
11-05-2021 11:00
11-05-2021 11:00
Have you found a tracker that works. ? I have an old fitbit blaze that has no issues reading my sleep. Upgraded to versa 2 few years ago and wouldn't track sleep over my tattoos so i returned it. Still wearing my old Blaze but dying for a newer model with more.
11-05-2021 11:22
11-05-2021 11:22
Hi, @Missy8050, welcome, It's my understanding that the inked skin layer compromises the LED/sensor array function. Your device measures the change in colour of the layer that is inked. There were quite a few enquiries a year or ago on this issue (try looking on the "search bar") at a time when I think the LED/sensor hardware was updated. Your best chance is to place the device over a non inked area.
Cheers
Gr4ndp4 | UK
11-05-2021 14:08
11-05-2021 14:08
Hi I have my sense working in my tattoo I found the lightest ink spot on my wrist and it works great but only on faded ink
