08-27-2020
07:19
10:58
EstuardoFitbit
08-27-2020
07:19
10:58
EstuardoFitbit
Does the Sense have the feature reminder to move?
08-27-2020 07:35
08-27-2020 07:35
Hi @SallyJoJo and welcome to the forum! The answer to your question is yes. The Sense, and all three new devices, will offer reminders to move.
08-27-2020 07:35
08-27-2020 07:35
01-15-2022 04:20
01-15-2022 04:20
I use the sense and I have never felt the vibration on my wrist. Have tried log off and setting it again too. Please suggest what needs to be done
Best Answer01-15-2022 06:57
01-15-2022 06:57
Check your vibration strength.
swipe left on your watch face twice. Tap on settings.
Swipe up to vibration and audio. Tap and select strong vibration. See if that helps.
01-15-2022 07:00
01-15-2022 07:00
Hi there, @MorningSun2020 - You can check to see if Reminders to Move are st to ON but doing the following:
This should get your wrist vibrating 10 minutes before the hour if you have not yet reached 250 steps. Please let us know if this helps.
01-16-2022 21:37
01-16-2022 21:37
no it doesn't at all
Best Answer01-16-2022 22:22 - edited 01-16-2022 22:22
The problem is the poor Sense vibration - while the Fitbit App offers reminders to move [for configurable hours] you may never feel the vibration.
Although the vibration is weak if you use a clock face with multiple reminders to move, such as SimpleClockPro, you are more likely to feel at least one of them, plus it displays how many steps done so far in the hour permanently.
