@meiland7 Fitbit changed the Exercise app when it designed the Sense/Versa 3 operating system. All of the exercises are listed on the device itself in the Exercise app. They start out in alphabetical order. After you use a shortcut, your list gets divided into your Recent, followed by everything else (still in alphabetical order). You favorites self populate the Recent list.
Laurie | Maryland
Laurie | Maryland
Thank you for the reply! What if the activity isn't on there? Like rowing for example? There's no way to get that on the watch?
Best Answer@meiland7 The Workout choice is the recommended choice for anything not on the list. When you use the Workout choice, you can change the name of the workout after you are done. When you go to the exercise details, there is a Categorize Exercise choice at the top. You should be able to change this to rowing.
Laurie | Maryland
Hello, Is there a way to improve the watch app by allowing to edit the list of exercises? It's quite annoying to be forced to re-categorize the exercice every time in the mobile app...
Thats great and all but there are exercises missing, I bought a rowing machine yesterday and went to add the exercise type but couldn't find it.
Found out you can no longer amend the list and this type is missing.
I used workout instead but it reports only 2 thirds of the calories I burnt according to the machine.
So how do we add specific exercise types now?
Or how do we vote to have them added, ad why on earth would you remove ones that existed previously?
Is there a better exercise type to choose in the meantime Eliptical or Spinning maybe?
