01-02-2021 05:34
01-02-2021 05:34
Cant see anything before “ this week” under exercise tab. Is there not a way to view the history? Thanks
Best Answer01-02-2021 06:33
01-02-2021 06:33
@Mannbrad What type of phone do you use, Android or iPhone? You are describing an app issue. I want to move your post to the correct app forum. This helps Fitbit see if users are having a new problem. Also, which version of the app do you have?
Also, when apps don't behave correctly, my first step is to delete the app, restart my phone, then re-download the app. Try that, too.
Laurie | Maryland
Best Answer01-02-2021 08:26
01-02-2021 08:26
I have an iPhone SE and if you maximise the view (2 arrows top right) and swipe to the right you can see previous weeks/months
