Hi @RKkaul. Welcome to the Forums.
Thanks for bringing this to our attention. Just to confirm, do you see this error message when using the ECG app on your Sense? Or is it when checking your results in the Fitbit app? Also, do you recall since when this started to happen?
In the meantime, let me recommend the following steps:
Hope this helps.
Best AnswerI have got the same issue as RKkaul, I can't open the ECG app on mobile phone, When I try to open ECG, it stated "Oops, looks like there's no Internet Connection", while there is no problem to open other apps.
I try to reboot my mobile, still doesn't work.
Hi @QQma. It's great to see you around.
Thanks for bringing this to our attention and for the steps tried on your own. Just to confirm, do you mean that you're unable to see your ECG results? Or is the issue when trying to access the ECG App settings? Does the same happen when using either Wi-Fi and mobile data connection?
In the meantime, I'd recommend the following steps:
Hope this helps.
