01-01-2021 02:56
01-01-2021 02:56
Hello!
I am having trouble with the ECG function, I can not start the the APP on the phone (Heart Rhythm Assessment tile within the Health Assessments & Reports section in the Fitbit app).
Every time I receive the same message (Oops, this isn't supported in your location...)
Link to the screen shoot: https://ibb.co/jZ9fsMM
[url=https://ibb.co/jZ9fsMM][img]https://i.ibb.co/k6VBv88/HRAM.jpg[/img][/url]
I have had a quick chat with the support team, saying that there are "some" problem regarding the ECG. Does anybody else have the same problem?
Does this mean my NEW FITBIT SENSE has an issue and I have to apply for replacement?
01-01-2021 03:03
01-01-2021 03:03
Sorry I forgot to write, my location is Austria as one of the supported countries.
Best Answer01-01-2021 23:26
01-01-2021 23:26
Try setting your location and language to American English temporarily, it may help get you past the installation phase problem.
Best Answer01-01-2021 23:37
01-01-2021 23:37
@Korosec there have been several reports on the forum. You can try reinstalling Fitbit app to see if it helps and reinstalling ECG app on your sense, but for majority of people problem got resolved within several hours.
Best Answer01-02-2021 02:26
01-02-2021 02:26
Thank you for your advice, but I have already done that. And the problem is the same. By the way I have instaled ECG app on the SENSE, but I can not use it.
Best Answer01-02-2021 02:34
01-02-2021 02:34
I have also tried all of your advice, but I am always stuck at the same SCREEN. I have removed and instaled a couple of times (same advice was by the support Team) Just no luck, it looks like I do not have granted access to the FITBIT service, which could be fixed fast, right?
Best Answer01-03-2021 13:34
01-03-2021 13:34
@Korosec yes. This seems as a backend issue. You need to ask them to escalate so level 2 can investigate.
Best Answer01-04-2021 01:53
01-04-2021 01:53
I recived a second mail from their support, that they are "investigating" the issue...
Hope they come up with a solution fast...
01-04-2021 08:47
01-04-2021 08:47
@Korosec just keep proding them. 😄 This should be cleared.
Best Answer07-18-2021 05:22
07-18-2021 05:22
Was this issue resolved somehow?
I'm located in the Netherlands (one of the supported countries), but I always get same error message that ECG is not supported in my location.
I tried restarting the Sense, but it didn't help.
