It is an app on Fitbit and not Google Play. On the phone Fitbit app tap on your image icon (top left in android phones). This brings you to the devices screen. Then tap on the Sense tab. This brings you to the Sense options. Tap the Apps tile, then on the tab for all apps. Easiest way from there is to do a search for ECG and it should bring up the app for download.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best AnswerI just got my fitbit sense today in the Isle of Man. Bought mainly for ECG. Frustratingly, I cannot find the app in "my app" or "all app" list.
Did you get sorted out?
@SUMO136 @Drthomasj I might be wrong but I think Isle has its own regulatory body independent of UK. That means separate approval.
I live o the IOM too and can't get ecg working on my new Sense. Did you ever get it sorted because I have had no luck with Fitbit support.
