03-04-2022 12:37
03-04-2022 12:37
My fitbit sence just quite working, only had it since December of 2021, had to go back to my blaze. Any suggestions on how to fix my issue? Thanks
21:43
07:08
03-04-2022
21:43
07:08
Hi @OttisStahlIII - as it is under warranty take it back to where you bought it for replacement with a new one.
If it wouldn't charge get a new charge cable as they often go faulty or it may need carefully cleaning in the 4 contact holes which collect grime. Don't use any sharp metallic objects as it will damage them.
