This entirely depends on what you are using on your sense. Do you have always on display, or do you have fitbit always allowing access to your location for weather. Do you have snore detection on? I was using that and it hammered the battery. I've found that just turning that off, has made a huge difference. I last charged around 60 hours ago so two nights of sleep. I'm 72% remaining. No GPS usage. Light exercise. I have turn to wake or whatever is on. iPhone here as well. Only thing I can think that would hurt you more with android is the sense does speech to text on those I think.
So I'd say you'd have to list more of what you're using and have on in order to assess this.
Hi @Inha - as @Visual97 says, it depends on what you are using.
Snore detection and SpO2 can use as much as 4 days [of the 6+].
Here are some significant issues How to resolve the Major issues causing short battery life.
