Hello,
I currently sync the sense with an Android device but have noticed I get about a day to 2 days on a single charge of the Fitbit sense. I only got the device about a week ago and it has been pretty consistent with this battery life. Looking for any suggestions that could be causing the issue.
Thanks!
Hi @Chase92 - have a look elsewhere in the forums, as others are experiencing the same issue since the last firmware update for Sense and Versa 3.
You can see some ideas in Can I extend my Fitbit device's battery life? but short of disabling many of the features such as Snore detection, removing the SpO2 tracker app and clock faces there is not much else you can do at the moment.
11-26-2021
04:51
12:49
11-26-2021
04:51
12:49
As @James.P says, some clock faces make regular access to the internet, it is probably better to use an autonomous clock face that doesn't need regular contact with the phone.
There are probably plenty in the Gallery, such as SimpleClocckPro which shows all the main statistics on the watch without needing a phone for some services. Then sync with the phone only when you want to record all the information from the watch.
The weather App requires to get it's information, it may help to temporarily refuse it's permissions [in the Fitbit App] just in case it is making regular contact and see if that improves battery life a little. .
Best AnswerHello @Chase92, This issue is mostly related to the clockface your using as some of them can quickly drain out your battery. All the clockfaces that I use usually give me about 5-6 days. I have made some of my clockfaces (both paid and free), that don't inhale your battery. If those clockfaces don't help then it could be the device itself. Contact Fitbit support here.
Weather Face (best battery life) [PAID]
Clean Stats [FREE]
Other clockfaces
If this answer works please mark this post as a Best Answer. ~ K.K Designs
