12-03-2020 13:29 - last edited on 04-20-2021 10:40 by DavideFitbit
I charged my Sense yesterday afternoon to a full charge and when I woke this morning my battery was completely dead! I haven't made any changes to my settings and actually had my watch off for a good hour or 2 as I was painting and didn't want to get paint on it. Any suggestions?
12-04-2020 06:52
12-04-2020 06:52
Hi @Riarooo and welcome to the forum. Please try re-starting your Sense. That’s normally the first thing to try in a case like this. Let us know if it helps.
12-05-2020 15:30
12-05-2020 15:30
Hi, welcome to the Community forums @Riarooo.
Thank you for sharing this information about the inconvenience you've experienced with the battery of your Fitbit Sense draining too fast.
Let me know if you were able to resolve after the restart procedure suggested earlier or if you continue to see the battery is draining very fast or within hours. You can find some additional information in this article to improve battery life as well.
Please keep me posted.
04-19-2021 09:16
04-19-2021 09:16
I’ve been having the exact same problem, restarted it twice, regular display, no gps and I’m still so confused
04-19-2021 14:09
04-19-2021 14:09
Sounds like the same problem I am having as noted in another thread. I wonder if it is a firmware issue since several of us seem to be experiencing this issue out of the blue? I tried a simple restart, uninstalled all non-default apps, disabled quick-view, set clock face to default, rechecked permissions/setting on my phone, and even reset my sense to factory settings. Nothing seems to be working. The latest thing I am trying is uninstalling the SPO2 app as just changing the clock face did not seem to disable SPO2 checking.
04-20-2021 10:46
04-20-2021 10:46
Hi, thank you for sharing that you've been experiencing the same inconvenience with your watch, @ColbyT, and welcome to the Community forums, @ColbyT.
If you already tried all the suggestions to improve battery life and continue to experience the same problem, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
06-05-2021 05:27 - last edited on 06-16-2021 08:20 by DavideFitbit
Have you managed to resolve this? Since past week my Sense battery runs of with half a day. Before it was 4-5 days. It seems that there has been update or something that has caused this and it is pretty annoying as in most mornings my battery has died during the night.
I am having the same problem since last week. Have done many restarts, but battery dies within hours. Before it was more like 4-5 days. It seems it is connected to when the iPhone bluetooth is on. How to get it fixed?
06-05-2021 05:36
06-05-2021 05:36
Hi @karolih - have you tried the suggestion below of re-starting your Sense? If you did that and it did not help, then please contact Fitbit Support.
06-06-2021 07:19
06-06-2021 07:19
06-06-2021 11:12
06-06-2021 11:12
I'm having the same issue and have reached out to FitBit chat twice in the last day. I was told the issue was with the FitBit app version on my iPhone. I was told to Force Quit the app and that would solve the issue. It did not. I reached back out this morning to Fitbit Chat and was told to patiently wait for the next app version. None of this makes sense. The issue started 2 days ago where my battery would completely drain after 12 hours or less. My FitBit app was last updated my iPhone over 2 weeks ago. I'm beyond frustrated.
06-06-2021 11:45 - edited 06-06-2021 11:46
Understood. The same thing happened to me, after doing a factory reset and removing the application from the phone(then adding it back on) then my battery life behaved. I also turned off bluetooth and only turned it on when I had to sync.
06-08-2021 11:13
06-08-2021 11:13
I had the same issue periodically over the last few weeks- fully charged at night, then dead in morning. I did all the suggestions I could find online- cleaned the contact points, disabled SpO2 app, shortened the display time, restarted the watch, etc, etc. Finally called Fitbit and within 5 minutes they advised me they were sending me a replacement. I suggest calling, not online chat- much quicker! I wonder if this isn't maybe a known issue by Fitbit? Since the Sense is so new, it's still under warranty for everyone. Good luck!
06-09-2021 08:57
06-09-2021 08:57
Thank you for your replies, and welcome to the Fitbit Community forums, @karolih @Lindsey_L @lablover55 @pdt.
Thank you for sharing that you've been having the same inconvenience with your Sense watch.
If you're using an iOS device with app version 3.41 or further, please try to:
If you're using an Android device and you already tried the steps listed here to improve battery life, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
06-15-2021 11:04
06-15-2021 11:04
I started having this same issue 2 days ago. Battery completely empty, charged to 100%, dead again within 4 hours. I have restarted it numerous times and gone through all the other trouble shooting suggestions. I'm sure I'm going to have to call support, but sharing that you're not alone and this issue is still happening! This is my 3rd fitbit that I've had problems with and most definitely is going to be my last!
06-15-2021 11:31
06-15-2021 11:31
So frustrating! And it's still happening to me. I've followed all the steps suggested and it won't solve the problem. I can't check my app during the day without force quitting it right after. If I don't, the battery is dead in hours. Does anyone from FitBit have any updates on when the new app version will be available or if there is something more to this problem than what was originally communicated? I find it ridiculous the owness is on the FitBit owner to follow all these extra steps to get their FitBit to operate as advertised.
06-16-2021 03:51
06-16-2021 03:51
Get this! I tried calling customer support yesterday. They were having “technical difficulties” and told me I’d have to call back later! 🤦🏽:female_sign:
06-16-2021 08:18 - edited 06-16-2021 08:31
@lmcginnis @Lindsey_L Thank you for your reply and confirming that you already tried all the steps mentioned earlier. In the case of iOS devices, I was able to verify that other users are experiencing the same problem and the team of the developers is already working to find a solution as soon as possible (with the next app version).
In the case for Android devices, I recommend that you contact the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
06-17-2021 04:07
06-17-2021 04:07
Exactly this is ridiculous and to have us phone with the below post is crazy. I am sure that you are just like me and work for a living!
06-17-2021 10:04
06-17-2021 10:04
Thank you for sharing your feedback about this, @SunsetRunner.
Unfortunately since all the troubleshooting steps found in the forums have been exhausted, it would be necessary to continue the assistance process with the Customer Support team. They will let you know how to proceed with this.
Have a great day.
06-17-2021 10:18 - edited 06-17-2021 10:19
I have and and was told the below . It has been acknowledged that this is an update issue however Customer service does not know that or are being told to just try to take our money.
Hi Melanie,
Thanks for troubleshooting with us.
Checking further, we see that you've contacted us about this issue previously through Twitter.
Since you’ve performed all the recommended troubleshoots, we can conclude that your device may be defective.
We see that your device is no longer in the warranty period, and therefore isn’t eligible for replacement.
You can still use the discount that we offered in the next 30 days from the day it was sent to you. Simply click the link on the email and choose the best Fitbit device for you.
We look forward to getting you back on track
