My Fitbit sense battery is draining within a day after the latest update which came for Fitbit app (iOS 15). Also, snore detection is turned off since I looked it up as one of the reasons for battery drain somewhere
A good first place to start is to Shutdown the watch from the watch Settings menu.
Wait at least 10 seconds before placing on the charger to restart and charge it.
A normal watch should be fully charged in about an hour and should last 4 -6 days depending on what options you have enabled.
Here is the list of the main battery drainers just in case, How to resolve the Major issues causing short battery life.
Thanks! Will try it and hope it fixes whatever has suddenly changed with the battery draining issue
I am hoping somewhere this issue is already known and Fitbit team is working on fixing it.
