Fitbit Sense button is stuck
I went to charge my Sense a few days ago as it was not responsive when I pressed the button.  It sat on the charger for several hours and still did not work.  After closer examination, I saw that the button was stuck in it's depressed state and nothing I have tried so far as dislodged it.  Any suggestions.
3 REPLIES 3
I would contact Support right away, @LannyN, the sensor isn't supposed to be stuck like that.  I would advise a restart, however, if you can't get the sensor working properly, you wont be able to boot the device back up.
Support can be reached via the link at the bottom of the page.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
That button will always appeared depressed.
My understanding is that it’s a solid state button.
Try to somehow verify the battery charge level through the app or clean cable prongs and charge points on the back of the watch. I use isopropyl alcohol and a Q-Tip. If you have a recessed prong on the charger, that’s the problem and it has been an issue with some.
Sense Activation 11/3/20\IPhone 12 Pro Max\SimpleClockPro Watch Face\Spigen Rugged Armor Pro Case/Band
Thanks for the reply. My Sense is not communicating with the app at all,
so I assume there is no charge. I don't have it with me, so I'll have to
check the pins later this evening.
