04-22-2022 17:25
04-22-2022 17:25
After being on two two different chargers for two days, my Sense won’t move past the Fitbit logo. How can I get it to start working again? My husband had the same Fitbit and both the chargers work on his unit. Thanks for your help.
04-23-2022 03:19
04-23-2022 03:19
Try restarting by using the button:
hold down button for ten seconds or so until the Fitbit logo returns and then release. Let it process.
Is it synced to the app so you can see the current charge rate?
04-23-2022 18:24
04-23-2022 18:24
Unfortunately, I did not mention in my post that I already tried the reset button several times with no luck. The app continues to look for but not find the Fitbit. I’m sure the unit is at zero charge by now. Thank you for the response. Greatly appreciated.
04-24-2022 20:07 - edited 04-24-2022 20:07
Hi @SunsetRunner - charging can often be problematic. Check things to do and check - How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
