perhaps it is the charger..
Hello @Nino1978. Nice to see you around! @JoseRomeropaba Welcome to the community forums!
@lablover55 Nice to see you around and thanks for your input!
@Nino1978 I appreciate your help in trying some troubleshooting steps and thank you for the information. At this time, I was able to see that you have contacted our Support Team and they are currently working on your case. I recommend keeping an eye on your inbox since they will get in touch with you shortly.
@JoseRomeropaba Your help is also very appreciated and since the issue has persisted, I recommend contacting our Support Team for additional assistance. Note that you can contact them through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
Best AnswerCiao, Support ask me to do factory reset as listed below, it is in italian hope it will help, mine its working again now.
1. Tieni premuto il pulsante per circa 8 secondi fino a quando lo schermo non si spegne.
2. Dopo lo spegnimento dello schermo, sentirai una breve vibrazione:
3. Una volta sentita la vibrazione, rilasciare il pulsante e premere immediatamente e tenere nuovamente premuto il pulsante.
4. Attendi fino a quando non viene visualizzato il logo Fitbit, una volta scomparso:
Rilascia immediatamente il pulsante e poi premilo immediatamente e tienilo nuovamente premuto, finché non senti una vibrazione.
Dopo aver sentito la vibrazione, rilascia il pulsante.
Questa vibrazione indica che hanno avviato il ripristino delle impostazioni di fabbrica.
:Una volta fatta questa procedura la preghiamo di configurare nuovamente il Fitbit al suo account.
