08-27-2023 00:30
08-27-2023 00:30
I purchased the Sense after my Ionics were recalled. Shortly after receiving it the strap kept coming loose whilst wearing. I received a replacement a d in no time the same thing happened. Absolutely a design fault. Can the moderator please stop emailing me offers, I shall switch to another brand which makes watches with a traditional strap. I have no wish to keep changing the straps , my Ionics were brilliant. Please remove me from the database for emails. Thank you
08-27-2023 18:57 - edited 08-27-2023 18:58
Did the same. Bought the all in one case/band.
08-27-2023 16:44
08-27-2023 16:44
I had the same problem. One of the bands broke off. Easy solution: I went on Amazon and bought a replacement. Search "Fitbit Sense Bands" The good thing is that the replacement is not individual straps but a whole solid unit. You just snap the base into it. Cost $21. Problem solved forever.
08-27-2023 22:47
08-27-2023 22:47
09-04-2023 11:50
09-04-2023 11:50
you're welcome.
09-05-2023 09:19
09-05-2023 09:19
Hi there, @Cybertiger617. Welcome to the Community. @BlazeRich Thanks for your great help!
@Cybertiger617 I'm glad the suggestions shared above were useful for you and I took the liberty to mark @BlazeRich's post as the Best Answer to help other members having the same question. In case you have some spare time, I'd like to invite you to visit our Health & Wellness board where you will find great tips and encouragement from other members.
Happy stepping!
