03-18-2021
13:39
05:20
WilsonFitbit
03-18-2021
13:39
05:20
WilsonFitbit
Is it normal? Does that have to be the case? Watching the video, you can see that only a few cheap Chinese devices catch the pulse in the sausage:
Fitbit Sense what is measured here placed on a wooden surface - pulse ?! But so Fitbit Sense is a smart device not from China and not for 4€.
Best AnswerAs I understand it, in this case, the best thing to do with Fitbit Sense is to either put it on the screen, because only then does the "pulse" meter turn off or does Fitbit Sense turn off completely every 30 minutes before going to the shower, and so on. Because otherwise Fitbit Sense doesn’t turn off smartly.
#Problem #Solved
Hello @R.M, it's great to see you around! Thanks for the video and for the information!
If you were wearing your Sense some minutes before putting it on the wooden surface, it is possible and normal that Heart Rate will still show up. After that, please restart your Sense following the instructions here.
Or you can turn off your Sense if you're not wearing it. Take into consideration that vibrations or any other movements can cause your Sense to track false information.
Hope this helps!
Best AnswerHi, @WilsonFitbit,
I’ve already written in support of Fitbit on Twitter and they can’t help it. Fitbit Sense and placed on your side shows a "pulse" on your wrist. Look at the picture: Fitbit Sense VS Huawei Honor Band 4. Fitbit team, your programmers are lazy losers.
By the way, he wasn’t on any arm at the time and the photo was taken after the video when Fitbit Sense was still lying on its side 10 minutes later.
And. I understand if it still showed up to 50-100, but when it showed 128, it would dismiss such programmers as lazy-losers immediately.
#Problem #Solved
@R.M Thank you for the pictures and for your input.
Your feedback is very appreciated and please note that our team is always working to enhance your experience with the Sense and your feedback is a big part of that process. I've seen that your post is marked as "Best Answer" so other users with a similar inquiry or concern can find your tips helpful.
See you around.
