03-20-2021 09:42
03-20-2021 09:42
Fitbit sense stopped syncing so unpaired and no it won't pair again.H Havetried turning bluetooth off and on, repairing fitbit, restarting fitbit, uninstalled and reinstalled app, logged out and back in. There is nothing I can think that is left to do. Please help
03-20-2021 11:58
03-20-2021 11:58
Logout of the Fitbit App, restart both watch and phone then try Tips to pair Sense via Bluetooth
If by repairing Fitbit you mean factory reset, you will need to do a setup of the watch again
In the phone Fitbit App Click on profile photo [top left] Click on + Set up a Device Follow the installation instructions |
03-20-2021 11:58
03-20-2021 11:58
03-21-2021 07:17
03-21-2021 07:17
I've been having this same issue. It happened about a month ago. I contacted support and they gave me the instructions to repair it. I had to do it a few times. It took me hours before it started working again. Was fine for about a month and now it's happening again. I'm trying to disconnect / re-pair it again and it's not working. I'm SO disappointed with my Fitbit Sense. I believe it to be a faulty product in so many ways.
03-21-2021 07:25
03-21-2021 07:54
03-21-2021 07:54
I managed to get my to pair by following the instructions but now it is only showing calories burned in the app and not tracking steps or sleep
03-21-2021 08:14
03-21-2021 08:14
@KerrR Well done.
Do you mean its not showing steps in the middle on the Fitbit App main today page?
You can click on Edit and move the elements around if thats the issue.
Or if you haven't done any steps so far try moving whilst wearing the watch, and see if it records the changes.
You won't get any data for when you weren't wearing the watch, or wasn't previously loaded into the App.
At worst if there is a Fitbit App issue you can clear the cache
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo notification setup. |
Best Answer03-21-2021 09:02
03-21-2021 09:02
I was able to get it to work - disabled blue tooth, removed the device, re-added the device, re-paired the device. It didn't work the first time. Worked the second time. Wish I didn't have to do this at all - not sure why it keeps running to the issue of non syncing. But at least it's working now. Hopefully will continue to work. Thanks for the reply!
Best Answer03-21-2021 09:08
03-21-2021 09:08
@rjkuser Thanks, if you want syncing to work constantly you need to check the battery saving options on your phone to make sure that the Fitbit App remains running in background
On the phone check battery optimizations [the options may be different in your version]
Also its a good idea to keep the phone and watch in close proximity so that they can communicate when needed.
03-21-2021 10:34
03-21-2021 10:34
My Fitbit Sense last synced around 10 am Saturday March 20th 2021. Tried all steps several times. Not working. Thinking of taking off the Sense and going back to older Charge 2 with a slight crack on the face.
