Hi @callie29 and welcome!
Under the watch itself, you should see 2 latches. These hold the band in place. If you push the buttons, they should release. Gently pull the band out. To put a new band in, push the band into the same place until you hear a soft "click". That "click" means that the band is securely in place and is ready to use.
one cruise ship at a time!
