06-03-2022
01:06
13:17
06-03-2022
01:06
13:17
Band latch went free. Not holding the band when pushed /inset into the latch. Latch mechanism is freely move and not have tension when releasing toward rest position. How to fix this issue.
06-03-2022 10:20
06-03-2022 10:20
Hi, @Zoom4, welcome to the community, is the band you are using a Fitbit band or a third party band? Check to ensure the aperture in the "Sense" case is free of any debris or grit. You may find this video instructive ( at 17.33) How to Set Up Fitbit Sense (Step-by-Step) - YouTube . If your problem persists you should contact "Customer Support" here, I recommend you use the chat facility or phone for a prompt response.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer06-03-2022 10:25
06-03-2022 10:25
Thanks for the comment. I am using Fitbit bands which are in good shape and condition but latch itself is not holding band it freely move when not band placed into it.
Best Answer06-03-2022 10:53
06-03-2022 10:53
I’m having the same problem and my watch is 10 days old, I think it’s a product problem. I contacted support and they told me I could send my watch back and they would send me a new one, but from reading how many others have this problem I’m not sure that will help. Very frustrating.
