09-03-2020 11:17
09-03-2020 11:17
So I'm guessing as me we have all pre-ordered and all thought about screen protectors has anyone brought any or have seen anything pacifically for the sense?? Look on Amazon but it's a mind field
09-03-2020 16:17 - edited 09-03-2020 16:24
09-04-2020 06:08
09-04-2020 06:08
09-09-2020 10:06
09-09-2020 10:06
I think this screen protector would make the Sense bulkier. Maybe look at this one https://www.amazon.com/Spectre-Shield-Protector-Accessory-Friendly/dp/B08GZR3BHJ/ref=sr_1_1_sspa?dch...
I know this one is just a film protector but it doesn't add bulk. Maybe there will be a tempered glass protector soon.
09-09-2020 10:10
09-09-2020 10:10
09-09-2020 10:15
09-09-2020 10:15
If you want something like this I can get it for you and send it. The protectors should way much at all so shipping should be very cheap.
09-09-2020 10:20
09-09-2020 10:20
09-12-2020 14:21
09-12-2020 14:21
Have you looked at aliexpress.com? They already have screen protectors and bands for the Versa Sense. Most of the screen protectors and bands sold on Amazon come from Ali Express/Ali Baba. Ali Express ships international to just about every country there is.
09-13-2020 04:04
09-13-2020 04:04
I'm wondering if these screen protectors and cases will interfere with the EDA readings. Maybe a screen protector will be fine, but certainly the case linked above will cause issues.
09-13-2020 12:28
09-13-2020 12:28
I ordered the screen protector not a screen case. I can let you know how they work. I just don't want to scratch or crack the screen. I will be getting the extended warranty too for that reason.
09-27-2020 05:24
09-27-2020 05:24
I ordered something similar for my Fitbit Sense. It does a good job of protecting the entire watch including the case. I already have plenty of scratches on this protector after a day of working in the garden. However, it seems to prevent the EDA scan from working, which requires palm contact with the outer metal ring.
09-27-2020 05:27
09-27-2020 05:27
09-27-2020 09:45
09-27-2020 09:45
@Dazzatron were you able to find some screen protectors for your Sense?
09-27-2020 09:57
09-27-2020 09:57
10-02-2020 17:36
10-02-2020 17:36
@Dazzatron I am able to get wet install screen protectors from Amazon if you want. I can send you some.
10-02-2020 18:17
10-02-2020 18:17
That's the one I have. The only problem would be EDA scan and ECG whenever they roll out. Since your fingers/palm need to be touching the metal frame. This one covers it entirely.
10-04-2020 04:48
10-04-2020 04:48
I bought these. They add a negligible amount of bulk but definitely protect the device all around (which I need as an active, busy mom!). Mine came with lots of finger prints inside and required polishing before putting on my Sense bc it made my screen look cloudy. Once cleaned, it was fine. The clear dulls the color of the gold body of the fitbit somewhat, but there doesn't seem to be any impact on screen sensitivity. The one thing I can't do with the TPU cover on is use thr EDA scanner :(.
10-04-2020 10:57
10-04-2020 10:57
I have bought a couple from Amazon. They work brilliantly but can’t do an EDA scan with them on and I’m suspecting the same thing will happen with the ECG app
10-05-2020 12:53
10-05-2020 12:53
The interference with the eda scan appears to be an issue with the "cases" that cover the screen and wrap around the sides, vs the wet application film screen protectors which don't appear to interfere with eda scan.
so if getting a film screen protector for just the screen you are probably ok, but if you are getting a "screen protector" that's more of a case and wraps around the device, you will need to remove it in order to use eda/ecg functionality.
10-09-2020 14:19
10-09-2020 14:19
How so? It doesn't cover the sensors.
