09-03-2020 11:17
09-03-2020 11:17
So I'm guessing as me we have all pre-ordered and all thought about screen protectors has anyone brought any or have seen anything pacifically for the sense?? Look on Amazon but it's a mind field
10-10-2020 01:55
10-10-2020 01:55
Best Answer10-23-2020 19:06
10-23-2020 19:06
I had the exact ones from the initial reply and I had to take it off to do the test.
Best Answer01-16-2021 16:38
01-16-2021 16:38
How did the screen protector work? Did it protect from your screen cracking? TY
Best Answer01-17-2021 07:54
01-17-2021 07:54
01-19-2021 18:26
01-19-2021 18:26
Update your experience please
Best Answer03-31-2022 10:51
03-31-2022 10:51
Hey there! I just got a fitbit sense and I can't find anything that doesn't leave my watch useless while protecting it. Could you tell me which protector did you en up buying?
Thank you!
Best Answer03-31-2022 17:52
03-31-2022 17:52
Liwin (4-Pack) 3D Screen... https://www.amazon.com/dp/B08HVDPRKJ?ref=ppx_pop_mob_ap_share
Not perfect. Edges come up at times, but leaves all functions in tact and protects the screen.
03-31-2022 23:10
03-31-2022 23:10
Best Answer04-01-2022 00:41 - edited 04-01-2022 00:45
I went with the nanw 4 pack, like others. Similar design as others. Covers the entire bezel which I think you need. The edges of the face glass are exposed and when you drop it, it cracks as a result. Only problem is doing yard work or heavy Sweat. Moisture gets under the protector. I wash watch and protector though. Always looking for something better. Any full coverage of edges will require removal for ecg.
may do the Spigen rugged armor pro.
11-18-2022 10:20
11-18-2022 10:20
it s because a small plastic bar which is suppose to end before the off and on side botton is on the button. I cut that plastic off and everything went to normal
