03-30-2022 10:14
03-30-2022 10:14
Where can I get my fitbit fixed? Can I send it somewhere? It's less than a year old and I haven't worn it for 6 months. I need help.
Best Answer03-30-2022 10:19
03-30-2022 10:19
Hi @shorty67 after not being used, you'll need to be sure you update the device, the app and do a few restarts of it. What's going on with it? There is no repair shop to send these devices.
Best Answer04-01-2022 14:57
04-01-2022 14:57
If it sat 6 Months unused, it's possible the battery is depleted beyond recovery. I have to charge my back up trackers Monthly. Some are on 0 charge just sitting turned off for a Month.
04-02-2022 02:01
04-02-2022 02:01
Hi @shorty67 - presumably its not charging - as others say it may take a while to resuscitate.
However it could need cleaning or the charge cable might be faulty, see links and instructions in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen which should get you sorted.
Best Answer04-02-2022 08:07
04-02-2022 08:07
You say it needs fixing, with no mention of what is wrong.
