Hi @BC1011 there are no repairs for these devices, but I think there is something you might be able to use to keep your Sense working for you. On Amazon, search for "protective band cover for Sense" and see what pops up. There is a band which takes the pebble portion and completely encompasses it, so it can be used. Some people have used it as a remedy for the broken tabs on the pebble which made it impossible to use a regular band. It might help you to continue using your device. Most are priced under $20. Many have glued it, but most seem to prefer the protective bands.
