03-06-2022 06:54
03-06-2022 06:54
looking for a free clock face that shows photos, date, time, steps and battery.
03-06-2022 10:16
03-06-2022 10:16
I searched "Picture" and maybe one of these is the clock you had on your Ionic.
03-06-2022 08:08 - edited 03-06-2022 11:07
Hello @Rodmayo and welcome to the Community. I'm not sure that you will find a clock face that meets all of your needs. You can search the Gallery by doing the following. Tap on your profile picture on your mobile app > Sense > Gallery. Slide the toggle to Clocks and use the Search feature. I would start with photos as the search word.
Laurie | Maryland
03-06-2022 10:04
03-06-2022 10:04
yes thanks I had an Icoic and found a good one and still trying to find it if it was made for the Sense cannot remember the name.
Best Answer03-06-2022 10:16
03-06-2022 10:16
03-06-2022 11:00
03-06-2022 11:00
Thanks much appreciate the info
Best Answer03-25-2022 01:25
03-25-2022 01:25
I just upgraded from Ionic to Sense as well & cant find the Clock face that I used in Ionic.
BTW how is your experience with Sense?
03-26-2022 21:24
03-27-2022 19:34
03-27-2022 19:34
Yeah. I did search & couldnt find it in sense. Anyway now using some default faces first as just started sense
