05-11-2023
14:04
12:55
ManuFitbit
05-11-2023
14:04
12:55
ManuFitbit
Fitbit.... REALLY... FIX YOUR *****
The Google Assistant feature worked for a long time, but in the last few months, I have to go in to the Fitbit Android app MULTIPLE TIMES A DAY where it shows "Voice Assistant--Google Assistant--Not Connected"
All I have to do is "reconnect" and it works again for some hours until I must do it again. (Fitbit Sense only says something wrong with Bluetooth <<--WRONG: sync works fine, it's just the G.A. that gets auto-disconnected.
Why did Fitbit break this? Now my Sense is essentially a $9 watch. This was THE MOST IMPORTANT FEAUTURE on my Sense...GONE.
I've written in bug-reports and feedback for almost 2 months and they seem to have all gone in to the trash.
Please test (for more than 2 minutes) and fix it...and fire the gypsy you hired to manage this code.
I've spent enough time trying to get Fitbit to simply LOOK/ACKNOWLEDGE this broken feature to pay for the latest iPhone and iWatch... I'm giving up. Maybe Costco will allow me to return my Fitbit since it's no longer performing as advertised.
Moderator edit: clarified subject.
Best Answer05-11-2023 19:22 - edited 05-11-2023 19:27
Hi @GoodGuy5000HD - this is a known bug that has been introduced. Hopefully a fix will be found, see https://community.fitbit.com/t5/Sense/Google-Assistant-won-t-stay-connected-to-my-Sense/m-p/5385370/...
It is possible that Google made changes to the way the Assistant works as has happened in the past when GA routines suddenly stopped working, just like in this case when it suddenly keeps getting disconnected.
