12-19-2020 18:07
12-19-2020 18:07
Hi,
I have my sense since few days and I cannot have it consistently work with Google assistant without reaching some kind of problem. For instance, I have used it for the whole day today but now I am facing the following error.
My phone is next to me. I have just sync the fitbit and my Google assistant is allowed to run in the background since it respond to the OK GOOGLE instructions.
What am I missing ?
Pierre
Best Answer12-21-2020 23:26
12-21-2020 23:26
@lemayp happens when Bluetooth connection is unstable. Only way out is to reboot the Fitbit. At least in my case...
12-21-2020 23:26
12-21-2020 23:26
12-22-2020 05:44
12-22-2020 05:44
@Marrrmaduke Thanks a lot for responding to my message and confirming that I am not the only one facing this problem. Actually, I faced the same problem for a second time yesterday evening, so for me, since I received my Sense, there was not a single day without a glitch with my experience with this new device.
This situation is worst than I initially thought, particularly for a user experience. Initially, I thought that it was "just" the Google Assistant that was impacted, but now I just realized that it impacts all my SMS/Emails/Etc notifications as I missed several of them during the evening. So I can't trust anymore my watch as I don't know if the Bluetooth died or not. There is no warning when the Bluetooth is not working anymore, and I discovered about the situation only because I pressed the Google Assistant button.
I did what you suggested, and after I reboot the watch the google assistant start to work again... and I received about 10 missed notifications.
12-22-2020 05:47
12-22-2020 05:47
Wow, as I was typing this, I just realised that the problem occurred once again for me.. The watch was rebooted about 3hrs ago and I am facing the exact same problem once again!
12-22-2020 07:28
12-22-2020 07:28
Ouch! That sucks. I had this problem once, but definitely not as frequently as you. It hasn't come back since I rebooted my phone.
12-22-2020 07:37
12-22-2020 07:37
@LizzyFitbit Would you be able to tell us if there is any bug tracking system used by the Fitbit development team to track bugs reported by customers and if so, if this situation is part of such a bug list? Is there a way to either follow such bugs or at least have some kind of way to refer to it in the future or request for an update?
When the Fitbit is no longer able to contact the phone, the user must be warned at the minimum. As I have several other Bluetooth devices using my phone and not losing their connections, this appears to me as a pure Fitbit problem.
12-23-2020 15:47
12-23-2020 15:47
@lemayp can you share your phone model and OS?
Best Answer12-23-2020 16:49
12-23-2020 16:49
@Marrrmaduke I use a Pixel 3 XL running Android 11.
12-23-2020 18:18
12-23-2020 18:18
@lemayp I must say it's bizarre. Only recently I switched from Pixel 3 to 5 and haven't had such issues. Silly question - have you made sure Fitbit app is not being optimized by Android? Do you have any other BT devices connected?
Best Answer12-23-2020 18:41
12-23-2020 18:41
@Marrrmaduke I wouldn't be able to answer this question as I don't how to control that:
"Silly question - have you made sure Fitbit app is not being optimized by Android"
As for other BT devices, yes I do have several such as my windows laptop ( I use the Microsoft application YourPhone), I have some wireless earbuds, etc. That being said, I don't recall experiencing the problem while using those. But sometimes I don't know since how long I have lost my connection.
Thanks for your concerns. Let's see if things improve over time. Today was the 6th days I use the Sense only.
Best Answer12-23-2020 20:45
12-23-2020 20:45
@lemayp go to settings on your android, Apps and Notifications, find Fitbit app, tap and scroll down to Advanced, tap Battery. Under Battery optimization it should say Not optimized.
Another thing to try is to turn off Adaptive bettery under main Battery settings of Android.
Best Answer12-24-2020 08:10
12-24-2020 08:10
@Marrrmaduke Regarding the first setting, it seems like I don't have control over it and the current value is "Background usage can't be restricted"
As suggested, I have disabled the adaptive battery and we will see the outcome.
This morning I woke up with the problem once again, although it was ok when I went to bed. My phone was on the main floor while I sleep on the first floor, is that enough to get into such situation? I restarted the Sense immediately, I don't know if getting closer to the phone would have resolved the situation, but in the past it wasn't: as soon as I faced the problem, only a restart resolved the problem.
Best Answer12-24-2020 10:14
12-24-2020 10:14
@lemayp yeah. It probably lost BT depending on the layout of your house. I usually manage ok with different floors but depending in which room I'm in, I may lose the connection.
Best Answer12-29-2020 13:39 - edited 12-29-2020 13:47
I still have daily problem with this and yesterday I officially reached support and they said they will reach to me by email eventually. I provided a link to this community exchange so they could see what I have tried to resolve the situation.
Here is the thing for me:
Basically, the feature is not available most of the time I want to use it.
No other Bluetooth device is requiring so much attention from me, not even close.
05-11-2021 06:13
05-11-2021 06:13
Hi there! I read up on your issue with Google assistant notifications and saw how the community suggested restarting the phone and restarting the watch. Your last post explained you were still having the issue so you reached out to the Fitbit Team and referenced this thread. What was their resolve? It's pretty frustrating since Google assistant isn't even a feature that I use. If I have to call them I'll probably want to start the process of a return! Thank you in advance ..
05-11-2021 06:49
05-11-2021 06:49
hi @Krysless2 with the help of the community I have completely resolved this situation over a couple of days of observations. My Sense might lose the connection with the google assistant once in a while now, maybe on a monthly basis when the app requires reconnecting it, or when my watch is too far from the phone to interact with it.
Few things that appeared as "annoying" during the first few days of owning the Sense got resolved over a small amount of time for me and I no longer face any big problems with it. I use the Google Assistant daily now, and I have found new ways to extend it with some IFTTT @"recipes", so I definitively use such integration much more than anticipated.
My biggest problem was an environmental one. I use the Fitbit application on my phone (where I synch ) and on my tablet (where I consume or look at stats) and the tablet was not properly configured since it was still attempting to sync with the watch. Two devices synchronizing with a single fitbit is not supported. Once I made sure the tablet would no longer attempt to connect to the Sense watch. and only gets its data from the web, all my problems with the google assistant connection got resolve.
I hope this helps.
04-30-2023 12:42
04-30-2023 12:42
I have the same problem as well. I initially ignored it, but it is now a issue since I have to constantly re-connect the Google Assistant.
05-11-2023 14:11
05-11-2023 14:11
Me too.. Fitbit broke it and won't acknowledge it -- I saw they're no longer including G.A. in new watches(?!), but they shouldn't be allowed to remove features for which we paid for.
