12-27-2021
06:39
17:28
EdsonFitbit
12-27-2021
06:39
17:28
EdsonFitbit
On my fitbit sense watch my Google assistant assistant was working fine of a sudden then when I try to Google assistant it comes back says something went wrong try again
I did that but it's still not working
17:27
05:56
01-05-2022
17:27
05:56
Welcome to the Fitbit Community, @joselfps1.
I'm sorry to hear about the difficulties you experienced with your Fitbit Sense. Thank you for trying to get them resolved before contacting us.
If you haven't done so, please turn off Google Assistant and turn it back on. For instructions, please visit this article and open the menu "How do I disconnect my voice assistant?". In addition, you can restart your Watch by following these steps.
Hope this helps.
Best Answer01-11-2022 07:22
01-11-2022 07:22
This is a frequent problem with my Sense. I can re-connect by:
- Rebooting the Sense.
- Reconnecting Bluetooth (to Sense not Sense Controls)
- Re-activating Google Assistant with the FitBit app on the Pixel Pro 6.
I've not done it enough times to know if I can skip step 1 but skipping straight to step 3 does not work.
13:55
05:56
01-11-2022
13:55
05:56
Welcome to the Fitbit Community, @SunsetRunner.
Thank you for sharing the steps you followed to resolve the issue with Google Assistant. If there is any update about this topic, it should be communicated as soon as possible.
See you around.
01-11-2022 22:11
01-11-2022 22:11
Hi @SunsetRunner - when there is an issue, does this also work
The disconnection in the first place implies there is a setup problem, such as battery saving closing a component needed to maintain a working connection.
