11-29-2020 13:42
11-29-2020 13:42
I'm trying to set up Google Assistant. It's showing the wrong email address. I can't figure out how to change it. Can anyone help me? TIA.
11-30-2020 21:39
11-30-2020 21:39
Maybe a screen shot who'll be needed. It should require you to log into your gmail address and not auto fill your email.
01-03-2021 00:17
01-03-2021 00:17
Mine is doing the same thing. It automatically picked an address - it is one I do not use anymore plus it isn't my FitBit email. Anyone having the same issue?
01-03-2021 00:17
01-03-2021 00:17
What do you mean screenshot who will be needed?
01-03-2021 02:18 - edited 01-03-2021 02:20
Which mobile OS are you using? Stating this information makes it a lot easier for people to assist.
If it's Android (although similar might be possible on iOS) have you tried going into your phones settings - scroll down to Google (Google services) and tap - is the correct Google account showing here? If not, tap on the email address and tap add another account. You should also be able to remove the incorrect account by tapping manage accounts on this device.
01-04-2021 10:22
01-04-2021 10:22
Hi @N8teGee with Android I would alsosuggest to check the same for @BrittanyLP
The android phone is registered to one or more specific gmail address'
06-29-2022 07:18
06-29-2022 07:18
Apparently it uses whatever is currently selected in your "Google" app.
Go to "Google" app, tap top-right corner (account icon), choose the active account. Done, your fitbit assistant uses the selected account.
07-07-2022 22:30
07-07-2022 22:30
Yes i am having the same issue. Did you figure it out?
07-10-2022 12:56
07-10-2022 12:56
I just solved it right before your comment.
07-11-2022 05:43
07-11-2022 05:43
Open the fitbit app
Tap the top left corner
Tap Sense
Tap Voice Assistant
Tap Google
Tap deactivate
Now set Google Assistant up. And log into the correct email address.
