Any way to get google assistant on the sense to work with mygmc like the alexa assistant does?
Best AnswerHi @Drkfalcon.
Have you already linked myGMC with Google assistant (as in you are able to issue commands from your Google home speakers etc)? If not, that's the first thing you need to do (some instructions here). If you already have, are you speaking the correct commands to the GA on your Sense. In some instances you have to phrase it like "askGMC to....".
If the two services are connected correctly, I see no reason why it shouldn't work the same as it does on any of your Google home speakers. I have no experience with that particular service, but all of my devices work as they would on a Google home speaker (the Sense just acts as another speaker).
I have everything linked works fine from my phone but my fitbit says gmc isn't supported on this device.
