Its probably not an option on the Sense.
However, the way to do it manually is to swipe left edge to the right to get to quick settings, and it can be turned on off from there.
Also recommend using the wrist motion icon [on the same screen] instead, it will preserve your battery life even more. Though this is a personal choice that may take time to get used to.
Best Answerthat seems rather odd, you have to manually turn off the AOD?
its quite annoying to sleep with. and also a waste of battery.
its got to be there somewhere. i will have to spend more time looking around.
06:23
08:27
06-25-2021
06:23
08:27
If it's a sleeping issue, schedule a sleep period, it should blank the display during that time.
You can test this by a swipe from the left edge to the right to get to quick settings, enable sleep mode and when the screen timeout occurs the display will blank and stay blank till you push the button, double tap the screen or turn off sleep mode.
