I have bought "replacement" bands for Sense fit bit in the past but for the past few weeks I have returned two that I bought from Amazon and they were NOT a fit at all as advertised for Sense. . Today I found a pack of 3 and they are a perfect fit!!! I found them at Meijer
Hi there @KarinBarkhurst!
A warm welcome to the Fitbit Community!
Thank you so much for sharing with us the experience you had finding a replacement for your Sense band and for your recommendation.
I'd suggest looking for a band for the Fitbit Sense in the Google Store: Accessories, so you can be sure that the bands will fit the Sense. The bands that you find in the section under Sense 2 are compatible with:
05-03-2025
15:45
07:38
MarioSFitbit
05-03-2025
15:45
07:38
MarioSFitbit
Fitbit... I searched that for more than a week or two with ZERO results!!!
Bought 2 different bands from Amazon that advertised "Sense" as being
compatible and they just weren't and I sent them back!!! I was looking at
Meijers for a replacement watch and I found Exactly what I needed for my 2
year old Fitbit Sense. Look at the picture's of what I found. It was a huge
gamble price wise that paid off big time. I included pictures of the
packaging.
Google acessories does NOT include Fitbit Sense replacement bands At All!!!!! I bought Fitbit sense because it had ALL of the features I wanted in a "wellness" watchI. I Went everywhere & nobody had an answer at all!!!!! Go with the brand name " WITH it" you will be grateful to find the perfect fit for your Sense watch!!! Period!!
Moderator edit - merged messages
Best AnswerHi @KarinBarkhurst. The Google Store page can be annoying. The Sense isn't on the list, because it is a discontinued model. The 24 mm band in the Google Store is the right band for your Sense.
Laurie | Maryland
Best AnswerI have been buying bands for my Sense and Sense 2, and for my wife’s Versa 3 from Amazon for years with no issues.
The same bands that fit the Sense and Versa 3 also fit the Sense 2, but some of them have trouble locking in, but a little filing on the shoulders of the plastic piece that slides into the watch fixes the problem.
I have a hard time paying Google $30.00 or more for a band when I can get 3 nylon stretchy bands on Amazon for $12.00.
Yeah I looked there. No Luck at all. I have Sense not a Sense 2.
I have both an original Sense and also a Sense 2, my wife has a Versa 3, the same band fits all of them.
