02-28-2021
03:53
17:30
LizzyFitbit
02-28-2021
03:53
17:30
LizzyFitbit
How can I turn up volume on alexa I can't hear it, I need to turn it up, please fitbit it's a whisper I don't want my watch shoved against my ear
Moderator edit: subject for clarity and updated label
17:33
09:43
03-01-2021
17:33
09:43
Hi @Googoojma, welcome! It's nice to see a new face around.
I understand what you're referring to and once you've said your request, tap the speaker icon > - icon or + icon to adjust the speaker volume. Please give it a try and let me know how it goes.
Hope this helps.
08:50
08:39
03-07-2021
08:50
08:39
Hi @Googoojma, it's good to see you again.
Thanks for trying the steps suggested above. Fitbit has received feedback about the speakers volume not being too loud and I'm sorry for this inconvenience. At this moment I'd recommend restarting your watch to refresh its performance and see if that helps. Please know that your comments won't go unnoticed as they'll help us to improve the Sense and its features.
Best AnswerHi all,
The issue is the volume at all. Per specifications only 75 dB with a distance of pess than 4 inch. At exactly that's the issue - you need to put your watch next to your ear.
The + / - of Alexa works. Just press twice or more the - button. After that you will notice that the volume will increase by pressing the + again.
17:58
04:01
03-09-2021
17:58
04:01
Hi @Googoojma and @sancho90, I hope you're doing well.
@Googoojma, thanks for trying the tips suggested in my post. I'm sorry that you're having this inconvenience. If you haven't done so, please give a try to the steps shared above to see how your Sense behaves when using Alexa.
@sancho90, thanks for your great suggestions. I'm sure your post will help other members experiencing similar issues.
