06-29-2021
15:46
18:24
LizzyFitbit
06-29-2021
15:46
18:24
LizzyFitbit
When is this coming to the fitbit sense? Or how can I enable it? Would really like to try this out.
Thanks
James
Hi @Mtappert in your phone's Fitbit App, tap the premium tab at the bottom.
Tap Snore and Noise.
Tap the gear icon
Enable Snore
This feature, since it eats up batteries is off by default.
Best Answer@Mtappert The snore detect option only works for the original Sense and Versa 3, and it sucks the battery, so make sure you are charged before you use it. The Sense 2 and Versa 4 can enable it during setup, but from reports the software doesn't support that feature, and they have stated it won't in the future. So you stated you have a Sense 2, so it won't work, return it and get the original Sense, then it will work.
@Mtappert Welcome to the Community. @Rich_Laue and @Jdsenter Thanks for stopping by to help our member.
@Mtappert Thanks for the details provided, as well as the steps tried prior to posting. As our friend mentioned, the Snore Detect feature is available only on the Sense and Versa 3, however, you won't be able to see this data when using the Sense 2. I'm sorry for this experience and your feedback is truly appreciated.
If you haven't done so, I'd encourage you to vote for this idea posted in the Feature Suggestions board so our developers can continue tracking this request over time.
