04-29-2021
07:14
10:31
WilsonFitbit
04-29-2021
07:14
10:31
WilsonFitbit
How do I know if my Fitbit sense if Fast Charging or not. Is it a problem if it slow charges.
04-29-2021 23:53 - edited 04-29-2021 23:53
You can use a clock face such as SimpleClockDuo which displays the current battery level permanently and gives the time it is expected to be fully charged. If the watch takes a lot longer it could indicate a charging issue.
05-08-2021 10:35
05-08-2021 10:35
Hello @Jkenn43. It's great to see you around! @Guy_ Thank you for your great input and I'm glad to see you around!
Adding to the post above, please note that charging your device to 100% may take 1-2 hours. Make sure you plug the charging cable that came with your Fitbit device into a USB port on your computer, a UL-certified USB wall charger, or another low-energy device. For instructions, I recommend visiting the following help article: How do I charge my Fitbit device?
If you notice your Sense isn't charging as expected, please refer to this help article for more troubleshooting steps: Why isn't my Fitbit device's battery charging?
Hope this helps.
